DMartin9N-2N
Good evening! This evening I believe I discovered what has been wrong with my 9N for months! (Similar topic to another recent post today!!).
I have been experiencing hard-to-start problems; Tried starting fluid, jumper box, replaced spark plugs. Still hard to start even in this warm weather. Well, today after an hour of steady grass-cutting, I went to turn the key off, and found there is an INTERMITTENT problem when key is wiggled. WELL,THERE IT IS, I thought to my self. So over the last months, while troubleshooting the seemingly hard-starting problem, the key switch was working sometimes, not working other times. I don't know why I never suspected it!! It is a cheap replacement 9N/2N type switch, over 25 years old. BTW, when I replace the switch, I should also install a pilot light that will verify power whenever the switch is turned on. Sorry, this is almost a rant.........
Dennis M. in W. Tenn.
