Company Logo Shop Now
Lift Cylinder piston
pakhoss
07-09-2020 07:03:02
When rebuilding the hydraulics on my 9n I put in a new lift cylinder piston that uses an o-ring. Just discovered I forgot to put in the back up washer, what's worse is everything is back in and the top cover is bolted down and sealed. Is the back up washer a must, what happens if I don't put it in?
JMOR
07-10-2020 11:52:25
 Re: Lift Cylinder piston in reply to pakhoss, 07-09-2020 07:03:02
Quoting Removed, click Modern View to seethat will sure make some happy! :(
Bob - MI
07-10-2020 11:26:29
I would bet that deep down you know the right answer on this one. I was happy to read the responses to see everyone on the same page.
Our company has a simple repair philosophy in that we find the cause of breakdown, determine what it will take to repair it and then look at the design and determine if we can improve it to last longer or make it easier to repair next time. It gets in the way of cheap and fast fixes but our uptime is so far better than before we can't go back. And we also have banned duct-tape being used for any repair other than a short term emergency fix.
pakhoss
07-10-2020 11:21:14
Thanks all, was purty sure that was the answer, but figured it wouldn't hurt to ask.
wore out
07-10-2020 10:02:25
Just repaired one of the steering cylinders from a "7400" John Deere.
The piston O-ring was torn up.
The last guy in there put the backup ring on the wrong side of the O-ring.
Of course, LOTS more pressure and movement there than a typical "N" 3-point cylinder.
Surprisingly, for a modern tractor, the old and replacement backup rings are leather.
JMOR
07-10-2020 09:53:28
Quoting Removed, click Modern View to seeWell, looks like you do have choices......."not to worry it will all work out", all the way up to "a disaster waiting to happen". Freedom is wunnerful! :)
John Deere D
07-10-2020 07:01:48
Good morning.....
I'm an owner, not an authority on "N" Ford Lift pistons, and "anti extrusion rings". My past carrier and responsibilities included a wide variety of machinery including PISTON RINGS and anti extrusion rings. Some made of LEATHER, others made from Teflon.. I had an individual who had forgotten to install the anti extrusion back up ring . Eventually the O-ring was forced between the Piston and bore....seized the machine! The anti extrusion ring must be installed on the proper side of the O-ring...
You now have a situation that shall come back to cause you a migraine..
Bob..Owner Ferguson TEA-20...MF 35 X...2-N Ford...and other Tractors..
Hobo,NC
07-10-2020 05:53:49
Yep the engineered "squeeze" can be a nightmare at times. I Just fixed an engineered squeeze nightmare yesterday one I have chased for over 20 years...
Go after that backer...
TheOldHokie
07-10-2020 03:27:01
The backup washer is used to support the oring against hydraulic pressure that pushes the edges of the oring into the gap between the piston and housing bore. This extrusion causes premature wear of the ring. The width of the oring groove is also increased to accommodate the backup washer and without it the oring will not get sufficient "squeeze" for the seal and the potential for damage from extrusion is increased even more than normal. Just a matter of time until it starts to tear and leak. How long is anyone's guess but it will not last as long as it should. If it were me I'd bite the bullet and fix my mistake - not a huge job or expense to make it right.
TOH
R Geiger
07-09-2020 10:12:36
One thing for sure is that it will fail, may be in days, may be longer.
Shaun Wallace
07-09-2020 07:40:46
It will roll a little bit more than normal. So will wear quicker but will last quite a while unless used every day a lot .
Copyright © 1997-2020 Yesterday's Tractor Co.
