Company Logo Shop Now
Ignition Trouble
r2nranch
07-08-2020 17:43:33
I have a Ford 2N 1942 Tractor that does not shut off when I turn the key to th off position. If the cho-ke is pulled out then the igition turns off. I have re-wired it several ways and receive the same results.
JMOR
07-09-2020 17:13:46
 Re: Ignition Trouble in reply to r2nranch, 07-08-2020 17:43:33
Quoting Removed, click Modern View to seeno, no, no "new".....just proper cleaning of the primary stoppage points!
r2nranch
07-09-2020 16:37:39
thanks everyone for the advice, switched some wiring around thanks to the diagrams, and key works, now just need it to run more the a bowl of fuel , it fills back up and restarts then runs that out and starts all over, new fuel bowl line and carb ?, thanks again for the help.
Tim PloughNman Daley
07-09-2020 03:25:29
Invest in the ESSENTIAL MANUALS then OEM style correct parts after troubleshooting for defects. "I have re-wired it several ways..." but you don't say if 6V/POS GRN or a 12V switch out job. Mucked up wiring is 90% of all non-starting/operating issues. Forget model and year, means nothing, since all 9N & 2Ns after s/n 12500 were the same. OEM 6V will have a 1-Wire/3 Brush 11 AMP 'A' Circuit Generator; the roundcan Cutout Circuit; the OEM Ballast Resistor; front mount distributor with square can coil; a 1-Wire Starter Motor with NO Solenoid; AMMETER; Key Switch; and Neutral Safety Pushbutton Start Switch all wired correctly. A 12V job requires a totally different wiring config. NOTE: 12V wiring requires use of the OEM Ballast Resistor and an external ceramic 1-OHM Resistor in-line as shown if coil is a 6V unit. Discard if 12V coil used.
FORD TRACTOR 9N & 2N, AFTER S/N 12500, OEM 6V/POS GRN WIRING:
FORD 9N-10505-B CUTOUT ľUSED AFTER S/N 12,500 TO S/N 258504 ON 9N & 2N MODELS ONLY:
FORD N-SERIES TRACTOR FRONT MOUNT DISTRIBUTOR 9N-12250 BALLAST RESISTOR:
WIRING PICTOGRAMS by JMOR; OEM 9N & 2N ELECTRICAL SETUP:
FORD 9N/2N ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
Tim Daley(MI)
Bill(Wis)
07-09-2020 00:17:15
Sounds like the "weak sister ignition switch" to me. (;>))
R Geiger
07-08-2020 18:43:04
does your 2n have a magneto?
rvirgil_KS
07-08-2020 18:43:08
Alternator or Generator charging system?
That is a common symptom with a 3 wire alternator conversion with no isolating device, such as lamp, diode or resistor in the line between switch and exciter post on alternator
JF in MI
07-09-2020 03:29:03
 Re: Ignition Trouble in reply to rvirgil_KS, 07-08-2020 18:43:08
Agreed. After my 12V conversion mine did the same thing until I put a diode in the voltage regulator "on" circuit.
Bruce (VA)
07-08-2020 18:20:17
Is there a reason for not replacing the ignition switch? Or even testing it?
Copyright © 1997-2020 Yesterday's Tractor Co.
