Company Logo Shop Now
Order Ford 8N Parts Online
Mid-Western Industries Model 802 Loader on 8N
Bjorn Lysne
07-08-2020 15:37:32
Does anybody have an idea of what I can do to replace the hydraulic cylinder on this loader? I broke my right cylinder and can't, for the life of me, find a replacement. YT would not allow me to post a picture, but its the top assembly that screws on to the main tube of the cylinder.
Thank you-
Bjorn
Caryc
07-11-2020 14:57:08
 Re: Mid-Western Industries Model 802 Loader on 8N in reply to Bjorn Lysne, 07-08-2020 15:37:32
At $600 for a new gland, a new cylinder was also my first thought.
TheOldHokie
07-09-2020 15:49:21
I have known for a while I work way to cheap. A new replacement cylinder is starting to look very economical. Not to mention awfully easy.
TOH
Bjorn Lysne
07-09-2020 07:15:25
Thank you for the suggestions. The first shop I took it to wanted $600 to remake the gland. Waiting on second shop's opinion. He mentioned the possibility of TIG welding with a nickle rod as a possible option.
TheOldHokie
07-09-2020 05:57:09
Making a replacement is not super difficult. IIRC I charged $65 for making this one 12 years ago. The price would be a good bit more today.
TOH
wore out
07-08-2020 21:52:13
Sounds like you need the cast iron "gland" that seals to the barrel and contains the rod seals.
Likely, a nearby welding/machine shop could make you one out of steel, it's been done many times.
Issue would be cost, if you're lucky you might find a semi-retired guy that has a little shop to make one for you reasonably.
Also, it's possible the old part could be welded or brazed.
R Geiger
07-08-2020 15:53:38
[quote="Bjorn Lysne"](reply to post at 16:37:32 07/08/20) [/qhttps://www.surpluscenter.com/Hydraulics/Hydraulic-Cylinders/Double-Acting-Hydraulic-Cylinders/uote]
might try here
Copyright © 1997-2020 Yesterday's Tractor Co.
