Company Logo Shop Now
Order Ford 8N Parts Online
Re: steering box fill plug on a ford 8N
Tim PloughNman Daley
07-02-2020 02:10:32
Did you see my post with pictures below??? You show the air cleaner mounting bolt -NOT the lube bolt.
TPD
ejensen
07-02-2020 14:23:24
 Re: steering box fill plug on a ford 8N in reply to Tim PloughNman Daley, 07-02-2020 02:10:32
Hi Tim,
Including a picture of the bolt I think you removed to add oil to the geacase on an 8N. Put the tiny end of my quart { outboard lower unit style for addinging to the gearcase on an ouatboard} 80 90 wt just runs out the hole. is this the correct place to add oil?
ejensen
07-02-2020 06:16:39
Tim,
Yes, I did see the picture You sent, thank you. Removed the proofmeter and removed the bolt that picture you sent has a zerk fitting in it. Put the pointed end of my 80-90 plastic container in the bolt hole and was unable to get oil through the bolt hole to the steering box. Will take a small wire from my shop and check to see if the bolt hole goes into the steering box
Copyright © 1997-2020 Yesterday's Tractor Co.
