Company Logo Shop Now
Order Ford 8N Parts Online
Re: steering box fill plug on a ford 8N
ejensen
06-30-2020 20:33:22
JB, Sending You a picture of what bolt I think you told me about for adding oil to the gear box. Please let me know if my picture of the bolt to remove to add oil is correct.
Thanks, Chris
Tim PloughNman Daley
07-02-2020 02:10:32
 Re: steering box fill plug on a ford 8N in reply to ejensen, 06-30-2020 20:33:22
Did you see my post with pictures below??? You show the air cleaner mounting bolt -NOT the lube bolt.
TPD
ejensen
07-02-2020 14:23:24
 Re: steering box fill plug on a ford 8N in reply to Tim PloughNman Daley, 07-02-2020 02:10:32
Hi Tim,
Including a picture of the bolt I think you removed to add oil to the geacase on an 8N. Put the tiny end of my quart { outboard lower unit style for addinging to the gearcase on an ouatboard} 80 90 wt just runs out the hole. is this the correct place to add oil?
ejensen
07-02-2020 06:16:39
Tim,
Yes, I did see the picture You sent, thank you. Removed the proofmeter and removed the bolt that picture you sent has a zerk fitting in it. Put the pointed end of my 80-90 plastic container in the bolt hole and was unable to get oil through the bolt hole to the steering box. Will take a small wire from my shop and check to see if the bolt hole goes into the steering box
Copyright © 1997-2020 Yesterday's Tractor Co.
