Re: Going to try a 8n brake job. Advice before ordering par
Jim L WA
You might need some extra gaskets to use as shims to adjust the axle bearings after replacing the seals. Other than that, take a photo of the brake assembly before taking it apart. The right and left sides are a little different. The right side uses only one retracting spring where the left side uses two and the larger shoe is on the top on one side and on the bottom on the other side. Good luck and let us know how it went.
