Company Logo Shop Now
Order Ford 8N Parts Online
Re: steering box fill plug on a ford 8N
Shaun Wallace
06-29-2020 12:37:09
Its one of the rear battery box bolts. Rite hand I think.
ejensen
06-30-2020 13:34:16
 Re: steering box fill plug on a ford 8N in reply to Shaun Wallace, 06-29-2020 12:37:09
Hi Shaun, I have removed bolts from battery box and bolts on side of housing. Still unable to find the fill port. The tractor is 15 miles from our shop. using it with a bushhog to keep a field cut. Will wait until we bring the tractor home and start removing things to find the fill port.
Chris
deanostoybox
06-30-2020 13:56:07
 Re: steering box fill plug on a ford 8N in reply to ejensen, 06-30-2020 13:34:16
Late 52 has a large pan head screw on the front of the steering column above the hood and below the steering wheel. If yours has that screw that is where you put the oil.
ejensen
06-30-2020 14:14:47
 Re: steering box fill plug on a ford 8N in reply to deanostoybox, 06-30-2020 13:56:07
Deanostoybox,
Thank you, Iíll check
Chris
deanostoybox
06-30-2020 16:20:56
 Re: steering box fill plug on a ford 8N in reply to ejensen, 06-30-2020 14:14:47
One other possibility comes to mind. If you have an aftermarket steering gearbox (Sparex) the oil fill plug is hidden under the dash mounting "saddle" centered 1-13/16" above the lower dash mounting bolt on the left side. You need to make a hole there or remove the dash to access it.
ejensen
06-30-2020 18:57:46
 Re: steering box fill plug on a ford 8N in reply to deanostoybox, 06-30-2020 16:20:56
Deanostoybox,
I bought the tractor used some time ago. Do not know what the previous owner might have had done to the tractor. He is deceased now. I Think I will have to remove the dash to access the the oil port for the steering box
Chris
Thank you for the reply
ejensen
06-30-2020 18:56:50
Deanostoybox,
Chris
ejensen
06-29-2020 14:09:32
tShaun,
Thank you,
chris
Copyright © 1997-2020 Yesterday's Tractor Co.
