Company Logo Shop Now
TractorLinks.com
Order Ford 8N Parts Online
8n lift only lifts at full throttle
bigwade
06-28-2020 19:41:51
Iíve been plagued with issues on the hydraulics on this 8n. After 2 pump rebuilds it started having an issue that the lift is now so weak it wonít lift an empty boom pole unless it is full throttle. The quadrant adjustment is all the way to the rear. It has a new style piston in the top lid that was recently replaced. It is full of fluid and leaking out of the bottom side cover hole. Iíve only had an issue with this before with very heavy implements.
carlntexas
07-01-2020 16:02:22
 Re: 8n lift only lifts at full throttle in reply to bigwade, 06-28-2020 19:41:51
You can put the side chamber gasket on backwards then it won't pump and you get to drop the pump again BTDT.
TheOldHokie
06-29-2020 18:45:22
I have a dozen or so.
TOH
bigwade
07-01-2020 06:13:37
 Re: 8n lift only lifts at full throttle in reply to TheOldHokie, 06-29-2020 18:45:22
Pulled the side cover and made it lift with the throttle at full throttle, saw turbulence on one side. On further inspection it seems the gasket on the pto side pump chamber busted out and was spraying fluid.
JMOR
06-29-2020 11:34:59
Quoting Removed, click Modern View to seeAny decent hydraulics supply house. I made mine faster than I could drive to town or order one. A 1/2 X 20TPI bolt as I recall , drilled thru, brazed to a 1/4 inch NPT nipple.
TheOldHokie
06-29-2020 06:21:44
Chain the lift down, connect a piece of tube to the test port and run it back into the transmission filler. Start the tractor and measure the rate of flow coming out the hose both at idle and WOT. My guess is its nowhere close to the roughly 2.8 GPM the pump is supposed to produce.
TOH
bigwade
06-29-2020 07:24:57
 Re: 8n lift only lifts at full throttle in reply to TheOldHokie, 06-29-2020 06:21:44
Is there any good place to get a fitting for the test port?
Copyright © 1997-2020 Yesterday's Tractor Co.
