Company Logo Shop Now
Tweety needs a temp tank
Bruce(OR)
06-24-2020 18:05:39
Got the grease gun holder figured out. I just need to fab a bit perhaps. I have an old one gallon gas tank and need to get it mounted temporarily to get this machine running long enough to get it cleaned up a tad bit. Any pics out there? Now I get to research battery cable mounting locations while trying to make this close to original.
JMOR
06-25-2020 20:36:45
 Re: Tweety needs a temp tank in reply to Bruce(OR), 06-24-2020 18:05:39
Quoting Removed, click Modern View to seeand what does this have to do with a temporary gas tank?????????????????? :roll:
HarryVanderpool
06-25-2020 20:07:31
Very, very nice job!
And worrying about "stock" is a personal choice.
It's your tractor; not the critics.
When it has a new owner some day they may be of the mind to make it factory original.
That's O.K because it will be THEIR tractor.
Again; very nice neat work!
Doug-Iowa
06-25-2020 19:19:00
My battery cable solution. Not stock but provides a place for the tender and wingnuts for easy disconnect.
Doug-Iowa
06-25-2020 19:13:05
All the basics - wood, screws, wire, and duct tape
Soaked
06-25-2020 17:08:50
I hang this old rototiller tank on the air filter. Use the band/ mount off the gen mount bracket. Has a sediment bowl and shut off. Very handy.
GB in MT.
06-25-2020 14:23:55
A couple more....but..... didn't taste as good as what JMOR's jug tasted!!???
GB
JMOR
06-25-2020 13:00:24
Emptying the container is best part.
lha
06-25-2020 12:01:57
I have several dirt bike tanks that I use as starting tanks to run older motors that like the N series motors. They work well as they mostly have 1/4" lines and I have adapters to fit 5/16" carbs.
Bruce(OR)
06-26-2020 12:51:19
 Re: Tweety needs a temp tank in reply to lha, 06-25-2020 12:01:57
Thank you to one and all! IO got the 00 cable made up today and found the braided cable. Those should get mounted today and . . . running tomorrow with any luck and a tad bit of ambition. After that comes the clean up followed by more clean up followed by more repairs. After that is disassembly and quite possibly a paint job of some sort.
Copyright © 1997-2020 Yesterday's Tractor Co.
