Company Logo Shop Now
Order Ford 9N Parts Online
Re: 9N Wiring
JMOR
06-23-2020 14:44:34
If you have decent jumper cables, use them to jump from your vehicle to tractor and see what starter does on 12v. So as to leave tractor cables, connections, switch "as is" as much as possible, remove the cables at the battery and connect jumpers to those cable ends. Leave ignition OFF, so as to avoid placing 12 volts on anything other than starter. 6v battery is totally out of picture. If you wish to be extra cautious, you can remove wire from BATT terminal of cut out, but since a good cut out will be open, it shouldn't matter.
LM1970
06-23-2020 15:27:42
 Re: 9N Wiring in reply to JMOR, 06-23-2020 14:44:34
I'll give this a try, if I can. I tried posting a picture of the starter.
It does say 6 Volt on it. Still ok to try 12 volts on it?
Copyright © 1997-2020 Yesterday's Tractor Co.
