Company Logo Shop Now
3pt chatter. (2N)
zeked
06-23-2020 10:37:27
When I pick up an implement with my 2N the lift arms chatter then lift to full up. The arms work ok after that but there is still chatter lifting from full down. Where do I start? I bought all of the recommended manuals but donít see a definite answer.
Can you talk me out of taking the whole thing apart? (I know I should)
Thanks Zeke
btzj02
06-24-2020 05:09:32
 Re: 3pt chatter. (2N) in reply to zeked, 06-23-2020 10:37:27
I had a similar issue. Had a valve stack hanging up. The shaft that had the binding valves is scuffed up and the spring seemed to have been compressed.
HarryVanderpool
06-23-2020 18:56:07
Our 2N would do the same thing, but just once in awhile.
Then it would clear up on it's own.
I always suspected a stuck valve, but was never sure.
I've been changing hyd fluid a bit more often (not every 20 yrs) and I cant remember the last time it chattered.
HFJ
06-23-2020 18:19:16
"No rest for the wicked"
... and the righteous don't need it ;)
Dean
06-23-2020 17:22:52
Can also be caused by muck in the valve chambers, which is probably the most common cause.
Dean
Bruce(VA)
06-23-2020 12:49:04
When the N lift is jerky coming up it means that one or more of the four pump cylinders is not pumping. It can be caused by broken springs in the pump chambers or a broken Scotch yoke in the pump that the pistons are attached to. Either one means the pump will need to be removed from the tractor to fix.
zeked
06-23-2020 13:58:59
 Re: 3pt chatter. (2N) in reply to Bruce(VA), 06-23-2020 12:49:04
Ok. Thanks. No rest for the wicked😳
Copyright © 1997-2020 Yesterday's Tractor Co.
