I have successfully built out the PTO cover plate with the appropriate oil seal.
My problem is that when I go to put it back on the tractor, I have about an 1/8" gap between the cover plate and where it bolts to.
The PTO shaft is solid and clunks when I tap it, so I know it is seated. The bearing sits inside the cover plate as it should.
Needing some suggestions now.
