Company Logo Shop Now
Order Ford 8N Parts Online
Re: Early 8n steering box leak
Tim PloughNman Daley
06-20-2020 04:00:20
Kudos if you have a 4-digit s/n -may want to consider a full OEM restoration. What is the casting date code? See PIC. A simple answer is NO, you need to yank steering box off in order to replace seals and bushings and so may as well do a whole rebuild at that point. "Steering Works Fine" but oil leaks out. How did you add oil? Thru steering wheel acorn nut? I told you it would. I fabbed my own lube plug with an NPT plug altered with a Zerk fitting to grease with 00 or 01 Cornhead grease but not going to help much until it is rebuilt correctly.
EARLY 8N ENGINE CASTING DATE CODE BOSS, SEPTEMBER 16, 1947:
FORD 8N STEERING BOX MODIIFIED LUBE PLUGS: EARLY- NPT; LATE - HEX BOLT:
FORD 8N TRACTOR, EARLY STEERING BOX, BEFORE S/N 263844 & MODIFIED ZERK/NPT PLUG:
FORD 8N TRACTOR, LATE STEERING BOX, AFER S/N 263844 & MODIFIED ZERK/BOLT:
Tim Daley(MI)
Copyright © 1997-2020 Yesterday's Tractor Co.
