Ok, long time lurker via Google. I have what I believe is a 46 9n. I'm in the process of changing the governor and the tractor now only has two speeds. Idle and overspeed
overspeed is achieved with one click of the throttle plate . I'm now aware I need to adjust the new governors internal play if you will via shims and the arms need adjusted with a ford governor jig. My question is where does one find this jig? My linkage is not threaded so it cant be adjusted that way. My only options are to bend the linkage or the governor arms, hence why I'm looking for the jig. Also, if i have this right, the shims on the shaft inside the governor are why I'm having engine speed control problems. Is this correct?
