Ok, so while working on the PTO problem, I pulled the shift lever cover off the transmission to check to see if there was anything weird in there (not). I didn't move anything in the transmission and put the cover back on. I have been using it for about an hour. All the gears were shifting correctly but it kept wanting to slip out of first gear as soon as the load let up. Now all of a sudden its like it is stuck in one gear. I thought I got it back together correctly since it was shifting normally but something changed. Does anyone have a picture of how the gear selectors are aligned at neutral for putting the cover on? Is there something I missed when I lowered the cover with the shift lever in the center?
Thanks...
Thanks...
