Company Logo Shop Now
Re: OT....Mini Tiller not starting
lha
06-17-2020 18:38:31
80lbs would be enough for it to run,but maybe not start. The muffler,if clogged would keep it from doing either. Burning it out with a propane torch or just put it on a small fire for a while will burn out the clog. The small two cycle engines are fairly sensitive to sitting around and to alcohol gas and the spark plugs sometimes get fouled. I run mine at 25/1 gas/oil with the mixture screws adjusted for richer mix to keep it from leaning out and holing the piston. I get them running[if possible]by turning with a drill on the end of the crankshaft and start off with some choke.
Copyright © 1997-2020 Yesterday's Tractor Co.
