Company Logo Shop Now
Order Ford 8N Parts Online
Re: Ford 8n Hydraulics
JMOR
06-16-2020 07:05:53
Quoting Removed, click Modern View to seeLook at my last input to this post (6/13/2020). Also, if you don't use draft control, you might simply tighten the big draft spring down real tight, thus preventing that input.
https://forums.yesterdaystractors.com/viewtopic.php?t=1435803 The sudden change from draft to position that I speak ofoccurs as you lower the touch control, because the normal setup is such that position control is in effect for most of the full travel of touch control, but draftis only over a very small range of touch control movement, so as a result when toy move touch control toward lower, it almost immediately switches from draft to position. Implement was full up in draft and next instand wants to go to whatever position control is set to (thus the slam).
Copyright © 1997-2020 Yesterday's Tractor Co.
