Company Logo Shop Now
Brake Adjustment
NCmau
06-15-2020 06:07:11
Left wheel, looking from the inspection hole. Do you turn the star wheel CW for loosening?
Both wheels are off. I did not remove the brake drum yet. The left wheel is freely turning forward. Backward, however is extremely hard to turn. Is the problem related to inside the drum or in the axle somewhere.
The right wheel rotates either direction fine.
NCmau
06-16-2020 04:50:19
 Re: Brake Adjustment in reply to NCmau, 06-15-2020 06:07:11
Nervous trigger finger.... dangerous!
NCmau
06-15-2020 15:09:39
Yep, I was going to remove the drum, just wanted a confirmation and like you said, it is most likely a lose-broken component.
NCmau
06-15-2020 15:09:18
R Geiger
06-15-2020 13:47:10
If it we my machine I would remove the drum, it sounds like you may have a broken spring! not that hard to do once you have the tires off.
Jim L WA
06-15-2020 10:55:27
I thought I had written that down somewhere, but can't find it now. However the FO-19 manual for my NAA says to turn the screw toward the rear of the tractor to tighten the brake.
Copyright © 1997-2020 Yesterday's Tractor Co.
