Company Logo Shop Now
Order Ford 8N Parts Online
Re: 8N fuel bowl gasket
TheOldHokie
06-14-2020 14:46:14
It doesn't matter what you are using - if you get it in the system it becomes a contaminant. The Permatex Aviation is insoluble and will form little gummy balls floating around if it gets in the system.
I much prefer PTFE tape to the aviation sesler and it works fine - just make sure you keep ithe wrap at least one thread back from the end of the pipe fitting. Just this morning I ran put of tape and had to make up some hydraulic fittings using the aviation sealer - always makes a mess because you cant avoid getting it on your hands when you handle the assembly. I think the chances of getting it in the system is significantly higher than the nice clean tape.
TOH
Copyright © 1997-2020 Yesterday's Tractor Co.
