Company Logo Shop Now
Order Ford 8N Parts Online
Ford 8N rebuilds
sabujur
06-13-2020 08:50:12
I'm rebuilding my Ford 8N engine, and saw they have 3, and 4 ring pistons for sale. I haven't pulled my engine yet, does anyone know if there is an advantage of one ring style over the other? thanks.
sabujur
06-14-2020 08:24:26
 Re: Ford 8N rebuilds in reply to sabujur, 06-13-2020 08:50:12
Thanks, I think I'll order the 3 ring pistons.
TheOldHokie
06-13-2020 17:30:52
Some also believe it was because of the the switch from steel to cast iron sleeves.
Nobody really knows but I think it's safe to say 3 ring pistons are the modern engineering standard.
TOH
mhb@ufe
06-13-2020 15:59:49
The 4 ring piston has an additional oil ring near the bottom of the piston. Some believe this wipes the cylinders down too much causing excessive wear from lack of lubrication between the pistons and cylinder walls. Some say that is the reason Ford went to the 3 ring piston but I can't verify that.
Mark
Jim WI
06-13-2020 15:34:45
Either that or the bean-counters. At this remove it's hard to tell.
TheOldHokie
06-13-2020 09:18:41
Quoting Removed, click Modern View to see Ford used both. Started OUT with four and switched to three. I think that pretty much indicates what their engineers thought.
TOH
Copyright © 1997-2020 Yesterday's Tractor Co.
