Company Logo Shop Now
Order Ford 8N Parts Online
Re: 8N Spark Plug Help
Tim PloughNman Daley
06-10-2020 05:02:13
You can get good copper core plug wires from a few suppliers- just have to search. Firing order is 1,2, 4, 3 and can be found in your Essential Manuals. By 'solenoid' do you mean the starter motor solenoid? The neutral safety starter pushbutton near the gear shifter isn't a solenoid. You verified those parts were defective before you bought new ones right? 90-95 percent of all non-starting issues are due to incorrect wiring. Is the OEM Ballast Resistor in the circuit? It should be. Is the OEM Generator and Voltage Regulator removed from the circuit? They should be removed. Are you running a front mount distributor? If so, is your coil the OEM 6V unit? If so, did you add an external 1-OHM ceramic resistor to the circuit? The Ford Angle (side) Mount distributor does NOT use the OEM Ballast Resistor.
FORD 8N TRACTOR WIRING DIAGRAMS:
FORD OEM BALLAST RESISTOR -USED ONLY WITH FRONT MOUNT DISTRIBUTOR:
HELP: The LH resistor Terminal Post connects to the COIL Stud Terminal Post as you face the back off dash. OEM Wiring is RED.
EXTERNAL 1-OHM CERAMIC RESISTOR - USED ONLY IF COIL IS 6V:
CORRECT FORD 8N ELECTRICAL SYSTEMS - 6V & 12V:
OEM 8N WIRING(6V/POS GRN) AFTER S/N 8N-263844 WITH ANGLE (SIDE) MOUNT DISTRIBUTOR:
*PICTOGRAMS courtesy of JMOR
FORD 8N TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
Tim Daley(MI)
Copyright © 1997-2020 Yesterday's Tractor Co.
