Company Logo Shop Now
Order Ford 8N Parts Online
Re: 8N Spark Plug Help
sde
06-09-2020 05:42:44
I thought that I had a spark problem also. I purchased an in-line spark tester at Harbor Freight for $4.99. I installed it on a plug and discovered that I was indeed getting juice to the plugs. I put gas in it and it started after a considerable amount of cranking. Turns out it was a gas delivery problem, not electrical. Being able to confirm that you are getting juice to the plugs is very important. Might help to buy the tester.
SDE
Bruce (VA)
06-09-2020 09:10:29
 Re: 8N Spark Plug Help in reply to sde, 06-09-2020 05:42:44
The problem with that $4.99 spark tester is that it's a light.
It takes about 22kv to fire the spark plugs in the engine. That light will come on at half that voltage giving you the impression that you have sufficient voltage to produce a spark in the cylinder. You don't.
A few dollars more will get you the tool you need: an adjustable gap spark checker:
https://shop.advanceautoparts.com/p/autocraft-ignition-tester-ac664/10051080-p?c3ch=PLA&c3nid=10051080-P&adtype=pla_with_promotion&product_channel=online&store_code=&gclid=CjwKCAjw5vz2BRAtEiwAbcVIL4fDqTvMHjNx-e_c_umSaUcxaVrCh2v0HYrR4Vy9WXQUWGKF2QxQ0xoCa6sQAvD_BwE&gclsrc=aw.ds
sde
06-09-2020 13:34:25
 Re: 8N Spark Plug Help in reply to Bruce (VA), 06-09-2020 09:10:29
My birthday is next month. Hint hint
Copyright © 1997-2020 Yesterday's Tractor Co.
