Company Logo Shop Now
Order Ford 8N Parts Online
Re: 8N51 Timing
wore out
06-08-2020 17:53:52
The "wear block" on the points isn't as "wide" as the point cam lobes, so wear would show up as a sort of wide "groove" in the face of the cam lobe with unworn cam profile "above" and/or "below" the worn area.
Have you looked closely at the #2 lobe?
I would suspect a worn distributor bushing and shaft, would cause the timing to "jump around" before I would suspect a worn cam lobe.
Could even have a bend to it, and flopping around.
Also, if the camshaft (for some reason) is moving fore and aft a bit that can cause "spark scatter" due to the angle-cut camshaft drive gears and angle-cut distributor drive gears. (Helical geartrins.)
Copyright © 1997-2020 Yesterday's Tractor Co.
