Company Logo Shop Now
Order Ford 9N Parts Online
Re: 9n PTO cap/guard
Tim PloughNman Daley
06-08-2020 13:37:25
Only two OEM PTO caps were used, all others are aftermarkets. The first 9N cap was cast iron and shorter. The 2N introduced the steel version, longer, and used thru the NAA. When the 1-3/8 PTO splined shaft was introduced, it was a tad longer than the original hence they offered a different cap -this is the one with the squared off end. Was your shaft changed and you are using the OEM cap?
PTO CAPS
NOTE: The 9N-726 cap is cast iron; the 2N-726 cap is stamped steel. Both have identical Thread Size of 2-5/8"-12 UN 2A.
Tim Daley(MI)
sde
06-09-2020 05:31:54
 Re: 9n PTO cap/guard in reply to Tim PloughNman Daley, 06-08-2020 13:37:25
The one on my 9n is cast iron and looks like the one on the left. I will have to check how far out the pto shaft sticks out from the tractor. It would still be the original pto shaft. The previous owner did not repair anything at all. He ran them into the ground and then replaced the tractor with another one.
TY
SDE
Copyright © 1997-2020 Yesterday's Tractor Co.
