Finally got around to the 8N this afternoon after fixing the injectors on the idi turbo diesel other Ford.
Pulled the engine block drain and then waited for the green to stop gurgling. Pulled the dip stick and the starter.
Pulled it all apart and then checked for a bench test short and found none.
Stuck relay? It's not pretty and the cable is vastly undersized. So I found another starter and relay and in about a week, those should be installed and then I try again to crank this over. I should thread in the old plugs just to keep out the ...?
The next week will be good clean up time for everything else.
The quarter in the photo shows the cable size in comparison. See any problems? Ground cable the same size.
