Company Logo Shop Now
Order Ford 9N Parts Online
9N Polarity Backwards Electronic ignition
JAFord9N
06-07-2020 18:34:14
Any input would be greatly appreciated and may save me some time and $. I was converting my early 9N from 6v pos ground to 12v neg ground, and installed new electronic ignition (12v coil). I clearly wasnt paying attention and hooked up the batt as pos ground and let the smoke out of the alternator, which I assume now is fried. I also fried the starter switch but I touched off the + lead on the starter using a jumper cable and will turn over. I couldn;t get it to fire that way so I pulled a plug to check spark and - no spark. Finally - my question is, do you think I fried the 12v distributor and/or the electronic ignition as well? I checked continuity and resistance across the coil and got about 2.4 ohms which I assume is good, but not sure.
Jim L WA
06-08-2020 07:58:26
 Re: 9N Polarity Backwards Electronic ignition in reply to JAFord9N, 06-07-2020 18:34:14
To answer your question, yes the points will work just fine with 12 volts.
JAFord9N
06-07-2020 21:10:01
Great thank you, ill try that
JMOR
06-07-2020 20:35:37
JAFord9N
06-07-2020 19:15:23
Thanks guys, not the news I was hoping for, but the news I expected. Know of any ways to check the EI before I throw the points back in it? Regular old points will work with a new 12v coil/system right?
R Geiger
06-07-2020 19:08:47
I doubt that you fried the starter switch, if you have the orginial one. it would not care what the polarity is.
David G
06-07-2020 19:00:12
EI is probably toast too.
Copyright © 1997-2020 Yesterday's Tractor Co.
