Company Logo Shop Now
Order Ford 8N Parts Online
Re: Ford 8N ignition problem
Shayneberlo
06-07-2020 07:12:10
[quote="CVPost-Bruce(VA)"](quoted from post at 18:10:59 06/06/20) " but I would imagine"
Why guess?
Confirm that you have a spark problem.....or not.
For example, the coil description says " This coil is used with an External Resistor if needed. " How do you know it needs one The only way to find out is to
measure the internal resistance of the coil. If it's 3.25 ohms or more, you do not need a resistor. And, while you are measuring, check the resistor. Some may
actually be .6 ohms as advertised.
The tractor was running good for a few years and I didn't make any modifications, so my thinking was something has failed or is failing. I replaced likely ignition and fuel parts but did not modify any existing configurations. The issue seems to be related to heat, as it runs well for a few minutes and then starts failing. I'm guessing that a spark gap tester would show good results during initial startup and then inconsistencies once it starts missing/sputtering?
Copyright © 1997-2020 Yesterday's Tractor Co.
