Company Logo Shop Now
Order Ford 8N Parts Online
Re: Ford 8N ignition problem
Shayneberlo
06-06-2020 17:33:30
thanks for your reply. Yes, I am using plan 1, replace everything. Primarily because the parts are very old anyway. I do not have spark gap tester, but I would imagine that it would show good spark when first started and then inconsistent spark after running it awhile.
Bruce(VA)
06-06-2020 18:10:59
 Re: Ford 8N ignition problem in reply to Shayneberlo, 06-06-2020 17:33:30
" but I would imagine"
Why guess?
Confirm that you have a spark problem.....or not.
For example, the coil description says " This coil is used with an External Resistor if needed. " How do you know it needs one The only way to find out is to measure the internal resistance of the coil. If it's 3.25 ohms or more, you do not need a resistor. And, while you are measuring, check the resistor. Some may actually be .6 ohms as advertised.
Copyright © 1997-2020 Yesterday's Tractor Co.
