thrutraffic
1952 8N-B
Just did a carb rebuild. All seemed to go well and the engine starts/idles great. But if I increase the throttle lever position the engine goes immediately to high revs. There’s no incremental climb in revs. This occurs over two or three bumps under the throttle indicator sweep.
I’ve got the master jet out two turns and the idle jet out one. Moving the throttle doesn’t over accurate the linkages so I know it isn’t a mechanical action causing it.
I’m pretty sure the problem is that I didn’t do something correctly either new carb parts.
Anyone know right off what would cause this?
