Hello. I recently had the top cover off my 8N to fix the typical leaking lift cylinder o-ring problem. Had to replace a worn cam follower pin and weld the cam back up to match its unworn edge while I was in there too. Also replaced the safety valve while I had it open for good measure. Got it all back together and verified that everything was moving OK and the control rod was moving the valve in the pump correctly before filling it up with fluid. Didn’t see any issues. Added fluid, fired it up and ran the arms up and down. All appeared fine.
Hooked it up to the brush hog today and picked it up no problem, but once I set it down it wouldn’t go up again. I pulled the inspection cover off and can’t see see any leaks. Stuck my hand down in the sump and verified that the control rod is in the cup of the rocket where it belongs, and it is, but the end of the rod is not moving when I move the touch control lever. I reached and verified the nut was on the end of the shaft that the control rod mounts to, but it’s as-if the rod is slipping on the shaft or binding somewhere.
I’m baffled here. Is there a common problem of some sort that would explain this? A bushing that wears, the shaft wearing, something with the control rod? Something I missed in reassembly (weren’t any parts left over)?
Any help is appreciated.
Thanks,
Adam
Thanks,
Adam
