67Chevrolet
Hello, I have an early Dearborn scrape blade made for the 8n tractor, I just have a question about it, when I remove the threaded bolt to swivel it, the blade seems to want to separate and it is a real pain to get it to swivel and then reingage the threaded bolt.
Is this normal, or maybe mine is wore out or missing a piece?
Just curious if others have this problem or if that s just how they work. It is the early style with pipe for the frame and a straight rod through the ends of the pipe frame to connect the 3 point arms to
Any insight would be appreciated
Thanks
Thanks
