I finished mowing and went to turn off the fuel, and the valve wheel was gone. Somewhere out there in the couple of acres I mowed is a wheel and a screw, and presumably a washer.
I have a few other sediment bowl assemblies around, so I decided to cannibalize a replacement. None of the screws fit the valve shaft.
Finally, I went to a 9N I have under repair and robbed the screw from it, and it fit. Nice. But I am still short a screw.
What gives here? Different size screws for the same part?
Has anyone else had this problem?
And where does one go to buy these tiny little screws?
I realize there are other solutions, such as just swapping out the whole assembly, but that doesn't answer the issue.
