8n Rear hub
flembo
Any one use one of these Rear Hubs from this sight 8N1171 and if so did it fit as it should and do you recommend it. Mine is worn and loose on the axle so I thought I may try it.
New one was loose for me. Evidently the axle is worn. Wish the hubs were broached or whatever slightly undersize to compensate for axle wear.
I had to put one on my NAA several years ago. I got mine from nnalert's and it fit very will. I was fortunate the the axle spline wasn't worn beyond use.
In years past Ford provided undersized hubs in 3 under sizes.
NLS since the late 70s/early 8os.
Dean
