Well, with the good comes some oops.
See if I remember how to post pics. . .
Here we have a "Strong Box" 6V battery.
Deader than a post I suspect and not going to waste time trying to make it work.
next pic is a bit strange. Isn't the tool box suppose to be under the lid? Loose wire anyone?
next pic is possibly an undersized batt cable that grounds out on the lower dash bracket. Barely. With the same loose wire that still needs a home.
next pic... A light switch and the home for the loose wire. Just great. I also get to tear this toy apart to eliminate the "Canary" yellow paint. Throughout.
next pic is uh... Steering arms!! To go along with the stiff steering (upper bearing? Blown bearing cage inside?) the steering arms are not straight across from each other.
next pic is the remnants of a steering wheel.
next pic is a shiny carb. Supposedly a part (in the carb?) took 6 months to order and then upon installation it broke.
The hand throttle is loosey goosey also.
next pic is a grease stain on the side if the bell housing that needs a hole drilled in it.
next pic is a Sherman Combo needing assembly and now had a future home.
So I have yet to pull plugs and oil the cylinders. Drain the clean looking oil, new filter, new battery, turn engine by hand first, crank over with plugs out, drain off gas tank. I should have already done that. Oops. Change out trans fluid, fill with 303 I believe, uh...
File the points, check the gap real fast and turn the key.
After cleaning off the excess oil that blows out, install the plugs, new ones that are not rusted and fire it off.
Last pic is a leaking brake drum. I can wobble the wheel on the axle shaft and see clearance. I guess I have another 8N around here, 2? 3? that will be donating parts towards this machine running again.
Suggestions, opinions and laughter accepted. I even braved the wife's scorn when I told her I bought another tractor.
Now to figure out what implement I will put behind it.
