Upper Steering Shaft Bearing Race : I need help
Thank you
I am doing the YT steering rebuild kit to replace all races, bearings and the cups. I have the bottom cup and bearing seated on the shaft. All races in the steering column.
The top bearing cup is my concern on the shaft. How far does it go down or in what manner do you nstall it so it is not too tight or too loose?
Manual doesn't cover it. I need your help.
Thank you.
I fixed it.
For those that may actually need help, I found heating it was not enough. After heat, I used a nut and washer to coerce it into place. This removed a majority of the slop.
