FrankOceanXray
Thank you
I am doing the YT steering rebuild kit to replace all races, bearings and the cups. I have the bottom cup and bearing seated on the shaft. All races in the steering column.
The top bearing cup is my concern on the shaft. How far does it go down or in what manner do you nstall it so it is not too tight or too loose?
Manual doesn't cover it. I need your help.
Thank you.
Thank you.
