8n Ford radius rod pins
Chaz7795
Does anyone know what size the pins are supposed to be that run through the radius rod forks and through the front axle on an 8n Ford, and how tight are they supposed to be in the fork and in the axle?
I see you've had no reply, and i keep forgetting to measure my bolt when I'm out by my 2N. I suspect they would be the same. I'd just make sure it is wrenched on their 'really tight'.
