oil pump bolts
lha
Does anyone know the torque for the oil pump bolts? The nearest I could find was 4.7 ft lbs. I appreciate any help I can get.
Thanks in advance.
I don't know how much help this will be, but over in the left column on this site is an area for Research & Info. In there, is Torque Values. It's broken down into the grade and size of bolt. B.T.W. nothing is listed for as little as 4.7 ft/lbs.
It shows 27lb for 5/15",but doesn't list 1/4",so I'll extrapolate the difference from 5/16 and 3/8". Thanks.
(quoted from post at 17:36:09 05/13/20) It shows 27lb for 5/15",but doesn't list 1/4",so I'll extrapolate the difference from 5/16 and 3/8". Thanks.
I hope you understand how to extrapolate cross sectional area of a round fastener....
Really, just snug them up with a short wrench and forget torque. :idea:
TOH
I found torque recommendations from several suppliers and for grade 8 bolts,from 7 lbs to 11 lbs was recommended. I set them
at 10 and tied them with safety wire.
Assume you're talking about the three oil pump cover to body bolts. These s/b 1/4-20 x 5/8.
Be careful looking up data and just winging it. You still torqued them too high. Probably not a big deal as most smaller bolts get tightened too much most of the time, and they usually take it OK. I just wouldn't do it in such a critical spot.
To use a torque spec, be sure to identify the bolts correctly. I can't image in any way these would be a grade 8. I'd worry about stripping out the threaded holes in the body or stretching the bolt itself.
My torque charts shows 1/4-20 cap screws in a grade 5 to be 6.3 - 7.3 ft lbs, and in a grade 8 to be 9 - 10 ft lbs.
TOH had it right, just snug them up good.
(quoted from post at 17:54:51 05/15/20)
Bolts are new grade 8,so 10 lbs is 8-10. I have been working on engines for 50+ years,but this tractor for only 17.
(quoted from post at 02:13:19 05/16/20)
/quote]New grade 8 bolts torqued at 10 which is 8-10. I have been working on engines for over 50 years,but only 17 years on this tractor,so don't know everything,so asked.
(quoted from post at 23:18:32 05/15/20) New grade 8 bolts torqued at 10 which is 8-10. I have been working on engines for over 50 years,but only 17 years on this tractor,so don't know everything,so asked.
i like to tighten them till something snaps, and then back it off a half a turn :) :idea:
(quoted from post at 05:20:32 05/16/20)
Thanks for the advice.
I went through three sets of bolts and finally got it right. At the point that I can feel it snapping,I back off. Thanks.
