Company Logo Shop Now
TractorLinks.com
Re: Slapping noise when under load
Dean
05-15-2020 08:51:53
Noises cannot be diagnosed in a chat forum.
That said, I would suggest that you verify proper ignition at all 4 spark plugs before doing anything else.
Dean
Philco
05-26-2020 06:42:31
 Re: Slapping noise when under load in reply to Dean, 05-15-2020 08:51:53
Hello Guys,
Re.: Slapping noise when tractor under load. I will check for proper ignition, and maybe put a timing light to test it. But that tractor runs so great and starts up like electronic ignition with no hesitation. I gotta pipe I can use as a stethascope to hear internal noises near the # 4 cylinder. And I'll check for exhaust leaks where both pipes join together. I bought new exhaust pipe several years ago, and used aluminum foil as a gasket to seal that joint better, so perhaps it may be coming from there. I retorqued the head last night since I just installed a new head gasket because of water leaking into the #2 cylinder and a lot of antifreeze in the oil, and changed that aloong w/ filter. I'll check the hydralic pump valve for noises there too. I'll let you guys know what I find. Thanks for all your input; it's appreciated.
Lastly, how do I switch the forum to Modern View...can't find it?
Thanks!
Philco
Copyright © 1997-2020 Yesterday's Tractor Co.
