Company Logo Shop Now
TractorLinks.com
Radius Arm Pins : Replacement?
FrankOceanXray
05-15-2020 06:07:12
Replace with pins or bolt with nut?
Bolts were used for mine. They were bent and threads wore off. Clearly need replaced.
Louis A
07-09-2020 15:19:23
 Re: Radius Arm Pins : Replacement? in reply to FrankOceanXray, 05-15-2020 06:07:12
Your 9N would have originally had bolts and nuts holding the radius rods to the front axle.
FrankOceanXray
05-16-2020 16:56:24
I keep mine I'm cardboard, too! I will place them as I got them, so the bolts even go back to the same holes.
I ordered some through Bolt Depot. Should be quick to get to me. They are MA. I'm in MD.
FrankOceanXray
05-15-2020 15:08:46
Hah, glad you specified. Correct police won't come near my tractor. WWII Early OD Green and will have a few other things not originally spec'd by Henry or Harry.
Thank you. Ordered some Grade 8s from BoltDepot. McCaster Carr just was too pricey with package pricing.
Bolt I removed had the threads all worn down.. didn't know if pin was best practice. Bolts it is.
Ultradog MN
05-16-2020 05:56:07
 Re: Radius Arm Pins : Replacement? in reply to FrankOceanXray, 05-15-2020 15:08:46
Just another plug for Bolt Depot.
I have ordered from them several times and got good prices and service from them.
Was looking for some round head and some oval head machine screws recently. BD had the round heads in steel but oval heads in stainless only. I wanted them to hold paint so had to source the steel oval heads elsewhere.
Ultradog MN
05-15-2020 14:38:37
Depends on what you are doing with the tractor. If you're building a trailer queen I might spring for the pins to keep the correct police off my back.
For a worker I would use regular bolts - grade 5 or better.
Copyright © 1997-2020 Yesterday's Tractor Co.
