Company Logo Shop Now
TractorLinks.com
oil pump bolts
lha
05-13-2020 10:44:36
Does anyone know the torque for the oil pump bolts? The nearest I could find was 4.7 ft lbs. I appreciate any help I can get. Thanks in advance.
lha
05-20-2020 16:10:45
 Re: oil pump bolts in reply to lha, 05-13-2020 10:44:36
Quoting Removed, click Modern View to see I went through three sets of bolts and finally got it right. At the point that I can feel it snapping,I back off. Thanks.
lha
05-15-2020 22:41:10
Quoting Removed, click Modern View to see Thanks for the advice.
HFJ
05-15-2020 22:20:32
i like to tighten them till something snaps, and then back it off a half a turn :) :idea:
lha
05-15-2020 19:18:32
Quoting Removed, click Modern View to seeNew grade 8 bolts torqued at 10 which is 8-10. I have been working on engines for over 50 years,but only 17 years on this tractor,so don't know everything,so asked.
lha
05-15-2020 19:13:19
jimtrs
05-15-2020 10:54:51
Assume you're talking about the three oil pump cover to body bolts. These s/b 1/4-20 x 5/8.
Be careful looking up data and just winging it. You still torqued them too high. Probably not a big deal as most smaller bolts get tightened too much most of the time, and they usually take it OK. I just wouldn't do it in such a critical spot.
To use a torque spec, be sure to identify the bolts correctly. I can't image in any way these would be a grade 8. I'd worry about stripping out the threaded holes in the body or stretching the bolt itself.
My torque charts shows 1/4-20 cap screws in a grade 5 to be 6.3 - 7.3 ft lbs, and in a grade 8 to be 9 - 10 ft lbs.
TOH had it right, just snug them up good.
TheOldHokie
05-13-2020 17:35:46
I hope you understand how to extrapolate cross sectional area of a round fastener....
Really, just snug them up with a short wrench and forget torque. :idea:
TOH
lha
05-15-2020 09:25:16
 Re: oil pump bolts in reply to TheOldHokie, 05-13-2020 17:35:46
I found torque recommendations from several suppliers and for grade 8 bolts,from 7 lbs to 11 lbs was recommended. I set them at 10 and tied them with safety wire.
Jim L WA
05-13-2020 13:06:40
I don't know how much help this will be, but over in the left column on this site is an area for Research & Info. In there, is Torque Values. It's broken down into the grade and size of bolt. B.T.W. nothing is listed for as little as 4.7 ft/lbs.
lha
05-13-2020 14:36:09
 Re: oil pump bolts in reply to Jim L WA, 05-13-2020 13:06:40
It shows 27lb for 5/15",but doesn't list 1/4",so I'll extrapolate the difference from 5/16 and 3/8". Thanks.
Copyright © 1997-2020 Yesterday's Tractor Co.
