front spindles
richiewis
04-30-2020 06:12:11
Ordered new front spindles for my 1942 ford 2n from this site. Got them put on and could not adjust the old style drag links for proper alignment. I cut off maybe 1-2 inches off one of the draglinks to shorten it and got it adjusted. How do you tell out of the box the difference in the right side 2n3105 and the left side 2n3106. I could not tell the difference when i looked at them before installing.Got a bad feeling I got 2 of the same side. There were no different numbers on the spindles. Any info appreciated. Thanks
Pappy
05-01-2020 03:58:04
 Re: front spindles in reply to richiewis, 04-30-2020 06:12:11
I had exactly the same problem. Both spindles were the same. Sent one back and got another. Same problem. My son took his die grinder and modifies the recess where the bolt goes through and was able to maintain the correct position for the arm.
richiewis
05-01-2020 05:18:42
 Re: front spindles in reply to Pappy, 05-01-2020 03:58:04
Appreciate the response back pappy, sure don't know what is different about the left and right side. Oh well nothin ain't easy I guess.
