I am not much of a social media person I don t typically post anything anywhere but do a lot of reading. My old 53 ford jubilee tractor I have had for 30 years has always been faithful but this springs startup hasn t went so well. I realize it s not a n series but it basically is mine is still all stock 6 volt was rebuilt a few years ago and has always served well. While not a mechanic I am somewhat mechanically inclined and am befuzzeled by what s going on with this tractor. Went thru my startup ritual and it fired right up but was way down on power. Cleaned points and reset made new pug wires as old ones looked tired took off carb and cleaned out noticed needle valve was not dropping freely but was changed last year put everything back together and restarted still not right. Pulled plug wires off one at a time it s only running on 1and 4. Good fire at all plugs checked compression over 100 on all cylinders double checked plug wire for correct routing still no change when plug wires pulled on 2 or 3 dies when you pull 1 or 4. Fresh gas I am at witts end any help would be appreciated. Thanks. c
