Order Ford 8N Parts Online
Ford 8N PTO/Hydraulic Lift
repsev
04-06-2020 16:45:45
Only had my 8n for 6 mths and noticed when I have the hydraulic lift all the way up with my shredder on it and disengage the PTO and shut off the tractor the Hydraulic Lift with the shredder lowers. A neighbor told me it should remain raised until I lower the lever, he said there must be a leak in the gaskets or bushings.
Should it stay raised? Or do they all lower when you disengage the PTO and shut the tractor off?
TheOldHokie
04-06-2020 18:00:08
 Re: Ford 8N PTO/Hydraulic Lift in reply to repsev, 04-06-2020 16:45:45
It lowers quickly but I am guessing that is in part to the heavy shredder I aways have on it. Is it worth repairing? My neighbor said he would give me a hand.[/quote:4713fb71e0]
If you can raise and transport it without issues I wouldn't worry about it. Sounds like it's only an issue when you park it and leaving a heavy implement raised is not a good idea anyway.
TOH
R Geiger
04-06-2020 17:59:53
You should never leave it raised in the first place, as long as it stays up while you are using it, I do not see it as a problem.
repsev
04-06-2020 17:02:02
JMOR
04-06-2020 16:56:50
A leak. Most will be ram piston/cylinder, but if it isn't interfering with your use, simpley ignore it.
TheOldHokie
04-06-2020 16:56:23
It "should" stay up but very few do. So how long does it take for yours to leak all the way down?
TOH
