9N oil pan - In need of
Abbby
Anyone have an oil pan for a 9N Ford they are willing to part with? I am located in western WI.
Tractor has been in the family for over 50 years and never been apart except for rear end. Engine was tired, clutch was shot, oil leaks and PTO shaft stuck. So decided to get it all done. I knew the oil pan had been brazed up prior to my Dad getting it. Now that engine is apart its apparent best to replace the oil pan. After putting transmission back on I put some oil in to confirm no leaks. That's when I discovered the crack in bottom of transmission housing. Way more then I bargained for but need to get er done.
Abby, I didn't really think you did anything to the oil pan. I was going to put a smiley face or something at the end of my post but forgot to.
I'm thinking in these strange times we are going through, it's a bit harder to find a little humor when it's meant to be there.
