i have two 8N's, neither are running
i have a front mount 8n that is mostly complete. engine turns freely but there is low compression on cyl 4, spark plugs show oil burning.
the side mount has a proof meter which i like
it has a crack in the left side of the block in the water jacket area that was repaired at some point with what appears to be JB weld. pressure test shows no leakage there.
my plan is to combine the best of the two tractors into one, and repair as needed for a refurbish/restoration. while i like the side mount for the proof meter function, i really didn't want to use the block that has the crack in it. i will likely need to overhaul either engine anyway, both engines show oil burning and carbon buildup on the plugs.
my understanding is there is no way to run a proof meter on a front mount engine, even if i swap the governor to the side mount governor. is this true?
is there some reason i should want to use the damaged side mount engine?
my 2N project is nearing its close, and its time to start making a plan for the 8N project. I am hopeful i can get them both complete before the tractor parades start in October and November this year.
