I need help in simple terms - I m a 66 yr old woman and don t know many mechanical words. I removed the 4 bolts around pto. It pulled out about 1/4" and stopped. I tried rotating slowly and pulling, no good. I removed the plate the pto shifter sits in (left side) and the top plate with starter and shifter. Lots of shiny stuff in there!
I read about cutting out pto shaft with a sawzall, but I will need step by step instructions. I see a lot of gears and the pto shaft, but no idea where the hydraulic pump is.
Tomorrow I will remove right side plate where hydraulic dipstick is. I will do anything to keep from splitting this tractor in half.
Thanks for any advice or pictures you can give to help me figure this out.
