1950 Ford 8n
(quoted from post at 12:37:02 03/24/20) How reliable are the County Line Carburetors. How do they compare to Chinese Carbs?
You don't suppose the ARE Chinese carburetors, do you?
Based upon my observations on this board as well as a few others, the failure record on the M/S clones is about 70/30.
You will be better off rebuilding your OEM M/S carb, having it rebuilt or buying a rebuilt one from a reputable source.
75 Tips
(quoted from post at 06:37:02 03/24/20) How reliable are the County Line Carburetors. How do they compare to Chinese Carbs?
I had two crack almost 10 years ago. Finally got one from Klems and that finally worked. We went through 4 carbs before this one worked. Should have rebuilt the old one.
