Fuel is still leaking from the carb. I originally thought it was seeping from the gasket below the nozzle (9N 9530). Replacing that did not help.
With the carb bowl in a vice and filled with gas you can see gas slowly coming up the economizer & idle opening"s (see arrows). It then seeps over and goes past the gasket & venturi (9N 9586) and then down past the nozzle, past the choke plate and onto the floor.
I understand why the gas comes up the two openings, but, how is it getting past the gasket and venturi? I have used a file on both sections.
We have owned this tractor for many, many years. This "seeping" just up and started about 5-6 months after I rebuilt the card about a year ago.
Tractor starts very easy and runs great.
Main gasket is brand new.
Venturi is metal and "appears" good. (?)
Any ideas will be appreciated.
Thanks, Tom/Idaho
Thanks, Tom/Idaho
